Panny ae100 or ???
Discussion in 'Projectors, Screens & Video Processors' started by JSW, Apr 23, 2002.
  1. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    I've been mulling over this pj for nearly 2 weeks now and almost pressing submit order on a couple of occassions.
    But I want to connect me Tosh SD900E via component and looking around here its not the pj for that.
    What else should I be looking at?
    I will also have a HCPC connected too.
    Many thanks
    Bry
  2. Guest
    If you already have a hcpc, why bother with the tosh?
    Just use VGA from the htpc to the panny.
  3. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    also, do we all really think the component in is that bad? I will be using component, and appreciate that the VGA is best (fair point floyd), but don't think it goes as far as AE100 is not worth buying because of poor component.
    Jsw, think of AE100 with component as best around (sub £2000), and great HCPC performance as a bonus. or do I have rose-tinted specs on?
  4. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Thanks Bonesy that was the sort or reply I was looking for :)
    Floyd:
    I Have the Tosh and very happy I am with it :)
    I have put my main pc from uptstairs down in the living room just to get a feel for girder etc im trying out with the pronto while I wait for my Dign case to arrive.
    Once the Dign arrives I will then build my HCPC as just that.
  5. Timh
    Timh
    Sep 14, 2000
    5,257
    3
    3
    Altair-4
    +339
    JSW
    I see you have a kp-41ds1, I also have this tv, the AE100 blows it away, the kp smears has poor geometry and has bad refection problems.
    I am that pleased with the AE100, I have let my Son have the KP-41 in his bedroom, he thinks its awsome playing his PS2 on it.
    I am using a Toshiba Sd-510 for R1 progressive playback, it looks very good, not as good as wide720 which I have tried, but its still very good.
    Sony KP-41ds1 = the worse purchase I ever made IMHO.
  6. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Hi Timh,
    I dont have any issues with geometry, colour or sharpness on my KP :) maybe this is due to a Sony engineer coming out and upgrading a couple of chips on a couple of boards in the tv so the cam from itv digital would work.
    Using the THX setup from Phantom menace the geometry is absoloutly spot on just like a sheet of graph paper :)
