panny AE 500
john59
An old one I know, but its still serving me well, just short off 1200 hours and still bright and cheerfull, Q here is Im thinking of buying a blueray player to hook up to it, will the pj be able to handle the player of my choice????????
Regards.
John
john59
Ahh, not sure about HDCP enabled,I am using HDMI at the moment on my tosh and picture is good
nwgarratt
Then it should work fine. It looks like it is not 1080p compatible so the player would have to be set to 720p. It has to downscale to 720p anyway so it doesn't really matter if the player or the PJ does it.
john59
THANKS FOR THE HEADS UP RE THE LINK, and thanks for the other info. Now which one do I choose with a budget of £100:)...........................Off to the blu ray player threads:clap:
