Panny A160 VCD playback
Discussion in 'Blu-ray & DVD Players & Recorders' started by Taz, Apr 21, 2002.
  1. Taz
    Taz
    Hi all,
    Why doesn't my recently purchased A160 play VCD's when all the reviews say it will?? ( even the machine has VCD on the front)
    If I use silver CD-R's it says "NO PLAY" if i use black CD-R's it says "NO DISC" yet both these discs play fine on my PC and my neighbour and boss' DVD players:confused:
    I must admit that VCD playback was the reason I bought the player as my old LG did not support it :(
    Taz.:cool:
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Taz, you may be in luck if you need to get rid of it.
    'If' you do, I'll pay you whatever you paid Tex for it.
    I'd buy it for my in laws.
    I still think it's non compatibility with the format of the vcd you're trying to play.;)
  4. Jungle Ted
    Jungle Ted
    Apr 22, 2002
    32
    11
    Crawley Down
    I have a Panasonic A100 - lower spec than your A160. My A100 will not read CDRs at all - I think you may have the same problem with the A160.
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,616
    Somewhere in South Yorkshire
    +6,162
    The problem is almost certainly NOT that it won't play VCDs. It is almost certainly that it can't read the data on CDR discs.
    Try copying your VCD onto a CDRW blank.
  6. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    VCD replay is a funny thing; ignore what it states on boxes, machines and paper. Take the VCD and try it in the actual machine to see if it works. As a side note price is not an indication of success. I tried to find a player to play my burned camcorder footage even Philips DVD recorder would not play them but they play on the computer OK. Pioneer seem to be closest to a unversal player.:confused:
