Panny 700 anda Denon dvd-2910..
Discussion in 'Projectors, Screens & Video Processors' started by jrosado, Apr 29, 2005.
  1. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    Are all the issues between the Panny 700 and the denon 2910 solved? I'm talking about the hdmi connection and the flashs (lost of signal that occurs). Do you guys think that this can be a good combination?
    Regards,
    J. Rosado
  2. rob j
    rob j
    Aug 10, 2002
    550
    +21
    I have this exact combination and I think it is superb :smashin: . It is connected via HDMI.
    However, my projector originally had version 1.3 firmware, which had the flashing and loss of signal problems.
    I got my projector back last week though after sending it off to Panasonic to upgrade the firmware to version 1.7.
    It has the fixed the flashing problem and has made the picture quality even better! :thumbsup: I must say I was very sceptical when first reading other post on here how the image quality could be improved!
  3. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    Can you tell me how many meters has your HDMI cable and what brand is it? Also, were did you get it?
    Regards,
    J. Rosado
  4. Spooksta
    Spooksta
    Nov 7, 2000
    2,648
    Planet Earth
    +267
    I have AE700 to Denon 1910 (HDMI-DVI) and the cable is 12m from forum sponsor. No problems at all with cable
  5. rob j
    rob j
    Aug 10, 2002
    550
    +21
    I have a 1m Supra HDMI cable and got it from here :)
  6. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    With a cable that had only 1m you had flashing issues ? :eek:
  7. rob j
    rob j
    Aug 10, 2002
    550
    +21
    The flashing does not come from the cable - it came as a result of the AE-700 being out of sync with the DVD player signal.
    The flashing was fixed after getting the firmware updated from Panasonic :)
  8. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    I thought the problem was with longer cables, and quality of them. I've a friend that with 10m cable and firmware 1.07 is still having the issue, using a denon 3910. With 8 meteres cable, there was no problem.
    Regards,
    J. Rosado
  9. Spooksta
    Spooksta
    Nov 7, 2000
    2,648
    Planet Earth
    +267
    I paid £185 for my 12m cable :p
  10. Tyjay
    Tyjay
    Apr 16, 2004
    7,386
    Bedlington
    +2,780
    10 metre profigold hdmi perfecto
