Panny 6 VGA Problem !HELP!
Discussion in 'Plasma TVs Forum' started by Oblivion, Jun 5, 2004.
  1. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Just setup my new Panny 6 and tried to connet my laptop to the VGA input. The problem is that the screen is all blurred+patchy and shifted to the left With a black bar down the left hand side of the screen.
    Any ideas? Scart + Component connections are fine.
    Paul
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Depending on your vga source, you can get a shifted image. Having to move and resize doesnt surprice me at all.....
    ad
  3. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Hi Buns
    I know that I can shift / resize the image. It s the quality, or lack of it that is worrying me. It has lots of tearing and black patches.
    I will try and take some pictures later.
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,687
    UK
    +116
    What OS and video drivers are you using?
    Also try setting some differnent resolutions...most people using a PC with their plasmas tend to use powerstrip to get the best pic...
    JJ
  5. CARLOS
    CARLOS
    Feb 11, 2001
    6,519
    WEST MIDLANDS
    +1,425
    It is switched to RGB and not Component in the menu ?
    Sorry i know its probably a stupid question :D
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I had my laptop on the my D6 panny and didnt notice any horrible problems..... it sounds a bit like there is a major setting which is just set wrong.... Carlos' suggestion is a good one, I cant think of any alternatives of the top of my head
    ad
  7. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Thanks to everyone for the comments.
    It was set to Sync on G, changed it to H & V and works a treat.
    This screen is amazing. Currently Using the Scart for Sky and compnent for DVD and Picture quality is fantastic. Almost on par with my old Tosh 32ZD26P. The back levels are just excellent. Just got to get the JS RGB2VGA now.
    Thanks again
    Paul
