Panny 6 sound query
Discussion in 'Plasma TVs Forum' started by SNICK, Jan 10, 2004.
  1. SNICK
    SNICK
    Feb 4, 2001
    793
    28
    UK
    +29
    the techical spec says this monitor has 2x8 W audio ? does that mean that you can connect speakers to the monitor to get sound?
    or what?
    thanks
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Basically...yes...you can buy speakers which attach to the side of the panel but I guess you could use your own as long as they are of the correct specification.
    Cheers, Lee
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    p.s. there are some Panny 6 speakers on ebay at the moment in the "TV and home cinema" section - search on "panasonic plasma"
    JJ
