Panny 6 Series - VGA Question
Discussion in 'Plasma TVs' started by woody123, Nov 19, 2003.
  1. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    Can any one confirm please that the 6 serise does take component input via the VGA connector on the Plasma?
    Also, if it does please let me know where can I find a diagram of the pin-outs? Pannys site is less then helpful.
    Thank you.
    James
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    It takes component video by the usual R, G & B pins (pins 1, 2 & 3 with ground on 6, 7 & 8)
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    i think he's asking if he can get YUV component into the vga port.
  4. Tee Tee
    Tee Tee
    Apr 3, 2002
    125
    Shropshire
    +3
    Yep, this definitely works as this is how I've got mine set up. Made the cable myself using shielded CAT5 cable.
  5. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    I mean Component in the form it comes out of a Denon 3803.
    Does this make any difference?
  6. deman77
    deman77
    Aug 20, 2003
    260
    16
    London
    only RGB not YUV
  7. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    It takes component video via the 15 pin d-sub socket. It uses the same pin configuration as RGB would i.e. the pins I laid out above. You will need a 3 RCA to 15 pin d-sub cable to do it (we stock these).
  8. woody123
    woody123
    Jun 30, 2003
    65
    Chelmsford
    Thanks Liam and all for the help.
