Panny 6 RGB to VGA alternative to JS Tech box
Discussion in 'Plasma TVs Forum' started by johngsuk, Sep 20, 2004.
  1. johngsuk
    johngsuk
    Hello am looking to buy a RGB to vga convertor and gawped at the price of the JS Technologies price tag of £120 looked at Maplins Website and found this. is this a similar product at under half the price? Has anyone got one?
    Goto Maplin.co.uk and type product code L05AN, this is what the description says:
    SCART Sync Separator
    This simple box allows the RGB output from DVD players, digital satellite & cable or any piece of equipment with an RGB SCART output, to connect to the 15pin connector commonly found on Plasma or LCD TVs and video projectors. Supplied with 15pin connection fly lead and mains PSU.
    · Input: RGB & Composite sync from DVD or Digital Satellite or Cable
    · Output: RGB plus separate Horizontal & Vertical syncs
    · For connection of AV equipment to Plasma, LCD TVs and Video projectors with 15pin inputs
    £42.54
    Regards John
  2. jimbo2
    jimbo2
    Jan 2, 2004
    130
    taunton,somerset
    +7
    looks interesting John! Anybody know if viable alternative to J.S box? :smashin:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,759
    The Borders
    +3,087
    Hello both
    Its as viable as a whole host of RGB Sync Extractors that have been tried head to head with the JS Technology converters and so far John's have always come out on top for image quality.
    Best regards
    Joe
    PS Keep in mind with all of these solutions you require a SCART Input cable and an HD15 (VGA) Output cable.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I'll second that, I have yet to see a serious rival both picture wise and signal tolerance wise, to the good Dr.'s products. His also come with decent technical support, both pre and post purchase. Check his website for device compatibility etc.
