Panny 6 Remote
Discussion in 'Plasma TVs Forum' started by Lydecker, Aug 30, 2003.
  1. Lydecker
    Lydecker
    I havent been able to find much info on the Series 6 Remote Control. Is it the same as the Series 5 one?
  2. blue_tarragon
    blue_tarragon
    Doesn't really matter. Programmed mine into my Universal remote and put it straight in a drawer with the other redundant 7 remotes
  3. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    The one I saw in the shop look identical but didn't get a close look. I'm guessing it has extra buttons for the picture in picture options?
    Neil.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Lydecker
    The new remote has a few extra buttons/functions (PIP as Neil suggests) though the basic style/layout is as per previous models; its still a 'toggle' to select inputs.
    One important feature of the PWD6 is that there is now an extra button on the front of the panel so you can access the menus without the remote.
    Best regards
    Joe
