Panny 6 Picture And Picture Options
Discussion in 'Plasma TVs Forum' started by I want a plasma, Jan 31, 2004.
  1. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Can anyone tell me what connections to my panny 6 is needed
    to get the PICTURE IN PICURE and the PICTURE AND PICTURE option to work.
    Any info would be great.
    Many thanks,
    Andy.
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    you need two separate inputs being used...e.g. input 1 and input 2 or input 3 and input 4 etc.
    JJ
  3. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    hI jj,
    Ok......so sorry to seem thick but is there one terminal board that will cover two imputs?? or should i get say a component board and a scart board.
    Cheers,
    Andy.
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Yeah, sorry thats what a meant...needs to be different input i.e. different terminal boards.
    Yes, if you have a scart and a component you can then pip & pap - or you could use scart and the VGA input to get PC and TV at the same time for example...
    JJ
  5. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Hi JJ,
    cheers for that.
    Looks like i got to spend more money on a component board and a scart board then.
    Oh well needs must and all that.
    Cheers,
    Andy.
  6. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    What boards have you got fitted at the moment ?
    Don`t forget the PC input that is already there !
  7. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Hi CARLOS,
    i have the tuner box with the tuner board [obviously]
    But i am selling these.
    So i am strting from scratch.
    I will be getting the component board. If the only way i can get to use picture and picture and picture in picture options i will get the scart board as well.
    Is that what i will need??????
    Will the picture and picture options work with this connection setup????
    Many thanks,
    Andy.
  8. _Sin
    _Sin
    Oct 25, 2003
    104
    +7
    If you ditch the tuner board, you'll still have a VGA input to play with. So you'd only need a component board to allow two things to be connected at once (bearing in mind the VGA-in on the panny lets you connect much more than just VGA signals, assuming you can find the right cable).
    Getting a scart board would allow you to have 3 seperate inputs, and give you a bit more choice - but it's not the best quality input for the panny.
