Panny 6 Owners.....please Help!
Discussion in 'Plasma TVs Forum' started by I want a plasma, Jan 11, 2004.
  1. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Hi all,
    ok,i know there are lots of answers to this question but i really need some help.
    Over the next few days i will be putting up a false wall[dry wall]
    so that i can hide all of the cables to my av setup.
    I want to get this sorted before i buy most of the equipment.
    So can anyone tell me what cables i will need to put behind the plasterboard to run the following.................
    1.PANNY6 PANEL
    2.PIONEER VSX-501-S A/V RECEIVER
    3.PIONEER S-VLF3 SPEAKERS
    4.PIONEER DVR-3100-S DVD RECORDER
    5.SKY+
    Any help and advice would be welcome.
    Many thanks.
    Andy.
  2. jmack
    jmack
    if you post a few more details i`m sure you will get more help.
    what imput boards do you have to go with panny?
    what outputs do you have on dvd player?
    are you planning on connecting a pc?
    how you planning on connecting sky+?
    does your amp have any video imputs and outputs? any signal upconversion?
    and speaker wires i`m sure you will work out,
    try to keep power cable at a distanst from your signal cables to avoid noise and interferance,
    hope this helps
  3. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    i knew this was not going to be easy:( :(
    Ok.....
    the dvd recorder has the following
    DVR-3100-S
    Input 1 SCART (AV connector2)
    2 RCA (Audio/Video) (front: 1)
    2 S-Video (front: 1)
    Output 1 SCART (AV connector 1)
    RGB Output
    1 RCA (Audio/Video)
    1 S-Video
    Optical Digital Audio
    the a/v receiver has the following.....
    Terminals VSX-C501-S
    Multi-Channel Input 5.1 ch (LR via SCART)
    Digital Input 4 (assign)
    Digital Coaxial input 1 (selective)
    Digital Optical input 3 (front 1)
    RCA Audio/Video Inputs 1A / 1AV (front 1)
    Preamp Output Yes (SW)
    A/V Input on Front Yes
    SR (System Remote) Terminal Yes (In/Out)
    Speaker A/B A only
    Euro Scart (in / in - out) 4 (2/2)
    Speaker Terminals Clip
    As i have yet to buy the panny 6 i have no imput boards.
    What do you recomend with this setup?
    Again,with sky+ whats the best way to connect with this setup?
    No to the pc.
    Many thanks,
    Andy.
  4. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Anyone want to help me out here??????
    Please.......
    Andy.
  5. AndyGo
    AndyGo
    Oct 5, 2003
    94
    9
    Wiltshire
    This is a bit of a monster one to answer in one hit, best to surf the threads to build up a picture.
    If you're gonna seal the cables in, best to cover all your bases by installing a good quality set of Component leads, a good scart, an S-video lead and a phono composite lead. At least then most options will be covered. Try Van Damme cables, they do a good range for reasonable price - the Scart & Component are a must have, might as well add the S-video & composite at the same time as for 20-30 quid you'll cover yourself for the future.
    I use a scart from the plasma to a Quintro switchbox, all RGB / composite sources go to this making things very simple, DVD via component (at least it will do when I get my Denon 2900 !) and that's that.
    There are umpteen other possibilities, but bury these in the wall & you'll cover yourself for 99.5% of possibilities up front.
    Also take the opportunity to bury the power cable & keep it away from the source leads as power cables induce an electrical field around them which can cause interference.
    Speaker cables & amp set-up ??!!! ...You pays yer money... !!!!
    (actually, buy a copy of essential Home Cinema mag, if I remember correctly they have a nice schematic of a set up at the back before the old reviews pages.)
    cheers,
    Andy
  6. I want a plasma
    I want a plasma
    Dec 9, 2003
    118
    16
    Milton keynes
    Hi Andy,
    many thanks for you words of wisdom.
    Cheers,
    Andy.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Scart from AMP to plasma (run S-vid and component as well) speaker cable for fronts if wall mounting.
    Run VGA as well just in case.
    POWER leads IEC thats about it really as for how you connect it up SKy+ RGB> amp
    DVD RGB>amp
    SKY+ Sbid + audio to DVDR S-video scart
    IF DVD-R is main DVD then optical or coax to amp, Sky+ optical to amp. RCA to SUB Speaker cable to speakers.
    JOB done pretty simple really, also run trunking in wall with 3+ lenths of thin string so you can pull an extra cables up.
