Panny 6 input slots
BiggieBig
got my panny 6 today PQ is excellent...
Thought i'd give it a test and then pack away until I have time to mount it...
Here’s the problem I encountered:-
I had two boards Scart & Component... Component was ok in slot 1 or 2.
But The scart would only works in Slot 2. When in slot 1 I get no signal or a funny greenish fuzz, the instructions say the scart is ok in slot 1 or 2.
Even though everything is working fine when scart is in slot 2 and the component in slot 1 but I’m just a little paranoid that maybe not all pins are working properly in slot1 ?..
Any thoughts ?
Dean
It should work in slot one, as I have my scart board in slot 1 via a quintro+ switching box. :confused:
MAW
I must say it's a new one on me, but your conclusion seems reasonable. You've tried re-seating it? That cures a multitude of sins. Power off of course.
BiggieBig
Does it really matter if component is ok in slot 1 ?.
just worried that some time in the future I may need to put a board in slot 1 which won't work
I need to decide if I want the screen changed !
Got the screen from DigtalDirect any one know the procedure do they just do a straight change or do I have to get it collected and then wait for another delivery ?.
MAW
With the £5 they make on the deal, I don't expect they'll be pleased to hear from you. I have no idea how they will deal with it. Incidentally, can you post the model number exactly as it is written on the box?
BiggieBig
MAW
Model number is TH-42PW6BX
I hope that's the UK model they claim it is ?
BiggieBig
Also was wondering if there are any setting that may effect the scart board not working in Slot 1.
or is it just simple plug & play......
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
