cwick
Did a quick search, but couldn't find anything. I hoping that some kind panny 6 owner can help me confirm if the following is a problem or a feature
If I put the panel into standby when the VGA input is live (VGA signal, not component - haven't tried that combo w.r.t. this problem), when the panel returns from standby only the VGA input is available (i.e. all other inputs are no longer there - can't toggle to them using the input control on the panel or the remote).
Only way to fix it (i.e. get other inputs back) is to switch off panel, disconnect the VGA feed, and switch on again.
It's odd, and I've not noticed this before, but I'm pretty sure that by some freak of luck I've never put it into standby with a live VGA signal before, so that would explain it. But I would like to know if it's just mine.
Cheers, Carl.
Cheers, Carl.
