Panny 6 discrete input codes?
Discussion in 'Plasma TVs Forum' started by MattTheBeanster, Dec 19, 2003.
  1. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,430
    Cornwall
    +100
    I have a pw6 and a pronto NG. The panny has a scart in slot 1 and 2 components in 2 and 3. Are there discrete codes to switch between inputs instead of using the toggle.
    Any help would be v.appreciated.
  2. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    I haven't heard anyone claim they've done.
    It was one of the annoyances when D6 has come out, that they kept Input and Ascpect ratio switching as toggle through, instead of assigning dedicated codes. With input it's not too bad as you are only likely to do that 2-3 times a night but with the aspect ratio (if you are not using scart) it's really bugging.
  3. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Sadly all I have to offer is a 'me too' - I'd dearly love discreet codes for the input selections.
    Cheers, Carl.
  4. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    Check out www.remotecentral.com
    At the moment discrete codes for inputs are not known. The generally best workaround is to use the PC code as a starting point (which is known discreetly) and then cycle round to the correct input as required. Not pretty, but seems to work...
    JJ
  5. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,430
    Cornwall
    +100
    feared as much.
    thanks for the feedback though guys.
