Panny 6 Default Inputs
Discussion in 'Plasma TVs Forum' started by Lydecker, Aug 29, 2003.
  1. Lydecker
    Lydecker
    On the commercial and consumer models of the Panny 6, what are the default inputs you get with the device. (The Panny 5 had Svideo, Component, and VGA). I have heard from some companies that the panny 6 comes with a SCART board - is this true by default?
    Many Thanks all.
  2. bond007
    bond007
    Aug 25, 2003
    90
    +5
    Yep, its true it comes with a single scart board, thats if the place you buy it from includes it, I know some dont. This accepts, s-video, composite and RGB. Also built into the display is a VGA connector, this accepts RGB and YUV (select which in the menu).
  3. Lydecker
    Lydecker
    Which are some of the companies that incude the scart by default then?
    THanks
