Panny 6 and J.S RGB to Plasma VGA ver2 Converter
Discussion in 'Plasma TVs Forum' started by Panosg, Jan 22, 2005.
  1. Panosg
    Panosg
    Sep 19, 2004
    898
    Somerset
    +3
    Hi all.I am sure that will be a damm question. :blush:
    I am looking to fit one of the above convertors from my sky+ to the plasma.
    My question is that.What is the litle audio jack under the panny 6 serries.Is this an audio input or a audio output. If it is a audio input can I then feed the audio from the J.S box audio output to this audio jack on the panny? :confused:
    Thanks for any help in advance. :thumbsup:
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Hornydragon pointed out to me that it is indeed an audio jack, I take it you have speakers on your plasma then?
  3. Panosg
    Panosg
    Sep 19, 2004
    898
    Somerset
    +3
    Thanks for your reply.HD and MAW always gave me good advice too so far.
    I do have speakers conected to the plasma yes.
    So It is a audio in jack....briliant.
    I have the sky + conected to the plasma with a high quality scart lead right now. Do you think if I use the J.S RGB Scart to plasma VGA will I notice any difrence? Will the extra money worth the purchace or should I stay with the Scart conection?Any opinions on that?
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Personally I do not like the VGA transcoder as you can not knock the colour back at all, and the panny colours on vga are too hot, I prefer the component transcoder, this with a vga to bnc cable and 3 bnc->rca converters and you are away.
    Definitely sharper than the scart input.
    Colours on the PW6 with the slider on -6. With it at -0 it looks like a cartoon.
    [​IMG]
  5. Likvid
    Likvid
    Dec 31, 2004
    497
    +9
    Thanks for that recommendation, you saved me money spending on the wrong product. :thumbsup:
