Panny 6 and Gamecube query
Discussion in 'Plasma TVs Forum' started by GAmbrose, Sep 10, 2003.
  1. GAmbrose
    GAmbrose
    Jul 5, 2003
    980
    43
    Essex
    +177
    Noticed recently when playing Fzero-GX and Soul Calibur II that the image isn't completely filling the screen. There seems to be black borders the whole way around the picture.
    NTSC Cube connected via Component to the VGA port using progressive scan, and both set to 16:9 widescreen mode in display options. Is this normal? I'll post pictures later. DVD's don't do this (though I don't have a progressive scan player)
    The rectangular border isn't very big, but I am surprised it doesn't fill the screen.
    Gary A
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    i think its because the cube dosent out put a true progressive signal. the xbox does and i dont get this problem. fits the screen nicely and is connected via component
    spec the pany is upconverting the cube but gettin it wrong.
    having said that turned of progressive output on xbox and it still fits the screen.........ummmmmm
    try a differnt input, say scart or super vid and see if it does the same. could be cube was never meant to be used in component out put (clucthes at straws)
    Try that and if its still the same then, er, well, em,:suicide:
    if not then i am a genious:lesson:
  3. bond007
    bond007
    Aug 25, 2003
    90
    +5
    Go into the panny menu and expand the image to fit the screen size/pos on the remote from what i remember.
  4. GAmbrose
    GAmbrose
    Jul 5, 2003
    980
    43
    Essex
    +177
    I would, but Gamecube and X-box are both going in on the same input.
    So then the X-box would be overstretched.
    Gary A
  5. jmack
    jmack
    gambrose i think it remembers size/pos for different signals so if gamecube is ntsc and the xbox is pal you should be ok
  6. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    ive read somwhere that the us cube dosent out put a true progressive signal.
    if u turn of prog does it fit the sreen as i have a couple of xbox games that refuse to play if prog is on, dont ask me why
  7. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    The cube does put out a true progressive signal.
    I think this has something to do with widescreen/non-widescreen.
    Regards,
    Neil.
  8. GAmbrose
    GAmbrose
    Jul 5, 2003
    980
    43
    Essex
    +177
    Both NTSC jmack :(
    Gary A
  9. StooMonster
    StooMonster
    Nov 20, 2002
    4,971
    Kent
    +314
    Progressive scan at 60fps takes four times the processing power of interlaced at 30fps -- therefore the developers may have reduced the screen resolution so they don't have to render as many pixels per frame.
    If it like this for all games, or just this one?
    StooMonster
  10. Timmy B
    Timmy B
    This is also the case with SC on xbox @ 480p 16:9. If you use 720p its 4:3 (well, borded 16:9).
