Figment
Established Member
Hi. I am wondering if it is possible to disable the Freeview Play banner that appears on the left of the start-up screen of my CX680.
I and I guess many others do not want to enter Freeview Play as soon as the TV turns on, but as long as that banner remains on screen (about 10-15 seconds) you cannot use the remote to use other functions. Even when the channel list update window appears at the same time the Freeview Play banner has priority and so if you press ok to accept the search for new channels it has no effect other than to loose the update option.
I have trawled the menus but can find no option to disable this bloody nuisance.
Any ideas guys? Thanks.
