Panny 52
D
Dominic85
Could i use a DVi to hdmi cable to connect to my pc to the panny 52, i know it doesn't have a pc input, but it does have a hdmi socket. this would be only a temporary arrangement until i buy a new monitor. can anyone :lease: help :smashin:
pknarb
The HDMI input on the 52 is a video input and not a PC input and hence some of the image will be chopped off as it's considered "overscan". If you're using an nvidia card, you can compensate for this in the driver settings but you won't be able to get a 1:1 pixel mapping.
