Panny 50 " wall mount ?
Discussion in 'Home Cinema Buying & Building' started by kingkarl, Jun 10, 2004.
  1. kingkarl
    kingkarl
    May 20, 2004
    3,560
    +1,614
    Hi Guys
    Can any of you recommend a wall mount for my Panny TH-50PHW6 that you yourself may be using ?
    Just rang unicol and they dont do one for this particular set so I was told.
    A picture of your installation would be nice if possible.
    Regards
    Karl :lease:
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Hi Karl,
    I am using the slimline tilting model available from the Power Buys section here :
    http://www.avforums.com/forums/showthread.php?t=130179&page=1
    I am very pleased with it. It seems well made and was very easy to fit and more importantly it's very easy to actually hang the plasma on the bracket - my previous wall mount for my Pioneer 433HDE was very difficult to actually locate the screen on the mount.
    I am still finishing off my room but here is a picture of it as-is now.
    [​IMG]
    Cheers, Lee
