Panny 50 picture settings
Discussion in 'Plasma TVs' started by Geeseman, Aug 4, 2003.
  1. Geeseman
    Geeseman
    I'm looking to buy a Panny 50", Id like some input from fellow panny owners on picture settings for the panel.
    What settings do you use for contrast, brightness etc?
    Thanks in advance
  2. sdh500
    sdh500
    The Panny 50" (series 5) already has 3 picture pre-settings: Cinema, Normal and Dynamic. Cinema is darkest, Dynamic is brightest and sharpest. I generally keep mine on Normal but slightly boost the Sharpness level. Sometimes I put it on Dynamic, especially when I'm showing it off or if a DVD has quite a dark transfer (like Star Trek The Motion Picture Directors Cut), but never use the Cinema setting which I find unacceptably dark.
    At the end of the day only you can decide what setting is best for you, though.
  3. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    'Only' got the 42" (Series 6) and it has Cinema, Normal, Dynamic and Auto.
    Like sdh500 I tend to keep mine on Normal, as Cinema really is very dark and auto tends to put it in Cinema mode all the time anyway.
    Gary A
  4. sdh500
    sdh500
  5. GAmbrose
    GAmbrose
    Jul 5, 2003
    824
    28
    Essex
    +73
    Hehe, bizzare.
    Gary A
  6. Geeseman
    Geeseman
    thanks guys.
    Anyone else here have the 50?
  7. sdh500
    sdh500
