Panny 5 series plasma - how to tell when displaying progressive
Discussion in 'Plasma TVs Forum' started by mark raeburn, Apr 28, 2003.
  1. mark raeburn
    mark raeburn
    Nov 14, 2002
    413
    +19
    I have a Panny 5 series plasma and was wondering how to tell if the screen is receiving a progressive signal from my PS2 via component.
    Mark
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Originally posted by jmack
    1.hold the volume button on the panell in while pressing the status button on the remote 3 times very fast (status button is the one under the power button)
    2. a menu appears highlight the icc menu and press sellect
    it should say in the top right hand corner what signal is showing ie 525p 525i 625p 625i.
    you must have your panell on the component imput and your dvd player on at the time of doing this
    to get out press the setup button then turn the panell off
    be carefull in there dont go changing things
  3. danny-p
    danny-p
    Is there a way of doing this with panny 4 series?
  4. jmack
    jmack
    same way not sure if it works if you have a tuner connected
    be carefull
