Panny 5 series PIP?
Discussion in 'Plasma TVs' started by Luc, Jan 3, 2004.
  1. Luc
    Luc
    Aug 7, 2000
    417
    Excuse the perhaps ignorance here, but i can't for the life of me find any info on getting PIP working on my 5 series Panasonic ('commercial' version, not the 'home' one). I haven't got the tuner board, but the component inputs, and Sky+ via a JS RGB>VGA to the vga port.
    How can i use both - say Xbox through the component and PS2 via the VGA (from rgb scart)? I think i read somewhere that the two inputs have to be the same type, so i can't have a progressive input and an interlaced one on screen at the same time, but i can't even find the option to try it? :mad:
    It does exist on the commercial version doesn't it? I'm sure i've seen Soul Calibur I / II running side by side on someone's plasma from an xbox/DC.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    That was mine and it was a Panny 6. 5 doesn't support PIP.
  3. Luc
    Luc
    Aug 7, 2000
    417
    Ahh, that'll be why i can't find the option!
