Panny 5 Quasie 100Hz
Discussion in 'Plasma TVs' started by Cummo, Aug 10, 2003.
  1. Cummo
    Cummo
    Jul 9, 2003
    27
    3
    Canberra, Australia
    Has anyone had the upgrade chip installed in their panny 5 series plasma with the eprom set to the Quasie 100Hz mode. The chip for my series 5 is presently on back order from Panasonic. I am interested to see how the reduced greyscale affects the picture quality.
  2. Geeseman
    Geeseman
    Is it a permanent feature or can it be turned on and off?
  3. Cummo
    Cummo
    Jul 9, 2003
    27
    3
    Canberra, Australia
    Geeseman,
    It is a first for the serviceman doing the job. I believe it can be reversed only by going back into the eprom and changing back the settings.
  4. pwarren
    pwarren
    Cummo
    This is the first I have heard of an upgrade chip for the flicker on a 5 series. Could you give the forum members some more details. Such as:-
    Who fits the upgrade?
    How much is it?
    Is it on-site or a return to base upgrade?
    Does it affect the warranty?
    Anybody got it installed yet?
    Very interesting, great thread!
    Take it easy
    Warren
  5. SherrifJWPepper
    SherrifJWPepper
    Hmmm this sounds interesting :)
  6. Cummo
    Cummo
    Jul 9, 2003
    27
    3
    Canberra, Australia
    The Australian Panasonic web site clearly advertisers their series 5 plasma as being flicker free. I have owned my SD model for 5 months & during that time have chased Panasonic for an answer to the problem. Having visited this forum I realised the problem is universal with the series 5 running a Pal signal.
    I have booked the plasma in (under warranty) to have the problem fixed. I have been advised that this is the first standard definition series 5 in the country to have this done. The technician doing the job has received a set of instructions indicating the procedure. This involves an upgrade chip to reset the eprom to Quasie 100Hz. mode. This chip is presently on back order from Japan.
    I have since spoken to a service technician in Melbourne, who advised he has set several 50HD models into 100Hz. mode (no chip required for the HD version). When questioned about the picture quality @ 100Hz. he said the picture was stable but blacks dropped off slightly in darker scenes.
    Hence my reason for the post. Has anyone set their sd series 5 into 100Hz. mode & what picture quality affects does it have.
  7. Geeseman
    Geeseman
    Hmm. I have the 50 series 5 unit and it does flicker as well, although I don't think it's as evident as the 42 SD unit.
    I understand you disappointment with the PAL display, but I will wait for a sollution that includes 60HZ PAL display for SD and HD material and not mess with the internals of the panel.
    Hopefully someone brings out a Digital STB that does 60hz PAL so we can have the 60 hz refresh rate and still keep the colour shades. I'm even considering a Home theatre PC for the job...
  8. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,046
    Born in Bristol but now in Newport, (for my sins)
    +657
    I wasn't under the impression that this was done with a 'chip'!
    I have been given the details of how to do this 'mod' on my series 5, but have to admit, havn't had the courage (or time) to do it yet.
    According to the info I have, its simply a memory register change which has to be made in the service menu, which will put the display in "Quazi 100" mode.
    However, talk of a 'chip' to 'reset the eeprom' has made me more nervous about experimenting with my display!
  9. mattsimis
    mattsimis
    Jul 27, 2003
    105
    Ireland
    Hi Jon,
    How about posting the source\info you have, perhaps someone else will do it for you!
    Im interested none the less.
    Matt
  10. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,046
    +657
    I am in a bit of a quandary about this. I was given the info in confidence, and managed to get it by stating that I WILL be the tester, but I have never had the courage to do it..
    My main concern is that I have an ongoing issue with my screen and am waiting for a man from Toshiba to come and see me and I don't want to jeopardise anything.
    I really need to find out from the originator of the info, the implications of giving it out before I do anything.
  11. mattsimis
    mattsimis
    Jul 27, 2003
    105
    Ireland
    Dont you have a Panasonic??
    Matt
  12. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,046
    +657
    Sorry.. Didn't see your quesiton until today.. I have a Toshiba WP27, which is a Panasonic Series 5 with a different badge.
    As far as I know, the software is exactly the same, so the 'mod' that I have will work on the Toshiba and Panasonic models!
