panny 5 progressive
Discussion in 'Plasma TVs Forum' started by brad, Dec 21, 2002.
  1. brad
    brad
    Feb 26, 2002
    839
    +77
    how do i tell when my panny 5 42'' is recieving a progressive input from my dv27 also any body know what the progressive thing is in the setup menu on the dv27 that you cant get to is
    cheers
    brad
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    You can't :( You should be able to tell though. Atleast I can with my Gamecube and Mario.
    Neil.
  3. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    You can view the screen mode 525i/525p/625i/625p on the Panny when entering the service menu (or whatever the menu with the hours counter in is called).
    Once you have entered the menu choose the first item (IIC). Display will (hopefully) show as 525p or 625p depending if ntsc or pal.
    Be careful in those menu's!!
    Rob
  4. brad
    brad
    Feb 26, 2002
    839
    +77
    how do i access the service menu to check these settings..??????
