panny 5 pixel problem - advice / experiences..
Discussion in 'Plasma TVs' started by FaxFan2002, Oct 11, 2003.
  1. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,114
    63
    Andover
    +109
    My panny 5 (3 month old) has just developed a pixed problem. An entire line of pixels (horizontal) near the bottom of the screen are displaying the incorrect colours - they don't look dead as the colours vary as too what is displayed around them... - I guess this is a call to panasonic? What are peoples experiences of this? Do they lend you a another panel? do they pickup - if so do they provide packing etc? What info do you need when you call them?
    Cheers,
    Rob.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,246
    The Borders
    +2,569
    Rob
    I'd power down the screen, disconnect it from the mains and 'pull' your RCA or BNC Terminal Board - you dont need to take it all the way out; just 'unseat' it.
    Then push it home again and fire up the system - quiet often this sorts out columns or rows of misbehaving pixels.
    Regards
    Joe
  3. FaxFan2002
    FaxFan2002
    Jan 25, 2003
    2,114
    63
    Andover
    +109
    Thanks Joe, but no joy I'm afraid. I should have mentioned it does do it on all inputs (vga).
    Looks like a job for panasonic - can anyone tell me (either via this forum or private message) how I can get information from the set on hours viewed ? (just so I can check when it comes back) - I promise not to change anything!
    Thanks,
    Rob.
  4. BigH
    BigH
    Dec 26, 2002
    447
    Hampshire
    +8
    Hi Rob,
    I had a warranty claim (twice!!) against my 50" PW5. No problems, Panasonic arranged full pick and collection (with a temporary panel) and they actually replaced it with a new one - twice!!
    Don 't worry about hours run just record the serial number before you return it. I suggest you do this through the company who sold you the panel.
    Regards,
