Panny 5 50" & Sky HD
Discussion in 'Sky Digital TV Forum' started by GregMarst, Mar 24, 2006.
  1. GregMarst
    GregMarst
    Dec 11, 2002
    68
    11
    London
    I've got a panny series 5 plasma (768 x something pixels) that is capable of displaying HD material but it can only display 1080i at 50hz. 720p only works at 60hz. It only has component inputs.
    This is what it says in the manual anyway - I don't suppose there is any chance it would work at both resolutions at 50hz is there?
    What is my best bet to get Sky HD? - I really don't want to buy a new screen - my wife would kill me!!! Would a scaler do the trick?
    Greg
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    a sclaer would but results likely to be less than ideal motion judder etc no HDCP input so its a limited time option, a new screen is the real answer
    Dont foget the VGA input its very flexible and if you went the scaler route thats how you would connect
    see here for some info on calibration which is very worthwhile if you go the scaler route www.homecinemaengineering.com
  3. scottymc
    scottymc
    Dec 9, 2003
    +8
    Hi mate,
    I did read on the Sky-HD forum,That you will be able to set the box to output
    1080i or 720p so sky hd should still be ok for you.
    Mind you mate alot of info flying about at the mo
    if someone could clarify ?
    try looking here mate
    http://www.digitalspy.co.uk/article/ds29403.html
  4. GregMarst
    GregMarst
    Dec 11, 2002
    68
    11
    London
    Thanks for the info. Can anyone confirm?
    Hope is an awful thing - I'd really convinced myself I wouldn't be able to get Sky HD, but now I getting my hopes up again!
    Greg
