Panny 42PWD6 input selection for RGB?????
Discussion in 'Plasma TVs Forum' started by nictry, Jul 3, 2004.
  1. nictry
    nictry
    Apr 28, 2002
    5,773
    Kent
    +645
    Just got my new Panny up and running and totally impressed so far, I have just been ahving a play with the menu settings and am not sure if something is nopt quite right or whether I am reading the manual wrong?
    I have a scart board added and one scart through via the Quintro box, now in settings it shows Input 1 and the RGB/Component bit is greyed out, if I change the siettings to RGB instead of Input 1 nothing happens and the above line is still greayed out??? I am confused as I thought I had to tell the screen that I was inputting RGB signals, can anyone clarify as I would hate to think I can get an even better set up if I do something differently in the menu :lease:
  2. nictry
    nictry
    Apr 28, 2002
    5,773
    Kent
    +645
    Anyone??????
  3. nictry
    nictry
    Apr 28, 2002
    5,773
    Kent
    +645
    Come on guys, someone must be able to answer this one for me, I just want to check whether the setting should be input 1 instead of RGB on a scart to scart connection to terminal board 1?????????
  4. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    The item you are changing is just the label for the input...it has no effect on the input settings at all.
    The SCART socket will automatically set itself to RGB if it's sent an RGB signal and PAL if it's sent a PAL signal...you do not have to configure it.
    Hope that helps.
    Cheers, Lee
  5. nictry
    nictry
    Apr 28, 2002
    5,773
    Kent
    +645
    Cheers, thought that was probably the case but needed an expert to confirm!
