Panny 42pwd6 going into standby mode
Discussion in 'Plasma TVs Forum' started by Biker Dave, Dec 14, 2004.
  1. Biker Dave
    Biker Dave
    Dec 14, 2004
    183
    +11
    Advice required please if anyone has experienced the following on their Panny:
    Screen is fine and then after no particular set time the screen puts itself into standby mode, however the standby LED does not remain constant red instead it goes from constant red to flashing 6 times then back to constant and the whole cycle repeats. If you turn the display off and then back on it will come back OK 9/10 times, if not it just goes into the mode dscibed above.
    Phoned Panasonic and the engineer believes it to be the power supply board at fault, they are coming to investigate next tuesday. This is great except as usual the screen is out of warranty by 1 month, ain't that the way! If this is the case can anyone give me an idea of the costing I need to brace myself for??
    Dave
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Biker Dave
    Biker Dave
    Dec 14, 2004
    183
    +11
    Thanks HornyDragon, will be having a chat with customer services!
  4. dempsey
    dempsey
    Yeah that'll be FOC it won't even be queried
  5. Biker Dave
    Biker Dave
    Dec 14, 2004
    183
    +11
    Thanks for advice
