Panny 42PW6 Connections - VGA configured to YUV
Discussion in 'Plasma TVs' started by rsamdal, Aug 4, 2003.
  1. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    Could someone confirm that the 42PW6 VGA port can be configured to accept component video signals (YUV) ?
    My setup will look like this:
    DVD2900 Component -> AVR3803 Component -> 42PW6 VGA (configured to YUV)
    X-BOX S-video -> AVR3803
    Tuner S-video -> AVR3803
    What type of YUV to VGA cable do I need ?
    Links to a online cable retailer that ships to Norway would be nice :)
    Is there any reason for choosing the TY-42TM6ZC Component board instead of using the VGA (configured to YUV) port ?
    Roger Samdal
    www.samdal.com
  2. GAmbrose
    GAmbrose
    Jul 5, 2003
    836
    28
    Essex
    +76
    It certainly can.
    The only reason would be to have an extra component connection if you have lots of things.
    Gary A
  3. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
  4. betamac
    betamac
    Thats cool, i was thinking i was gona have to get like 2 Video boards for the plasma i plan on getting,
    Instead you are saying i can get a VGA lead to go from Plasma to my Sony DB-1070 AMP
    then plug My DVD player and Gamecube into Component on Amp?
    and get true Progressive Scan?>
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,418
    The Borders
    +2,591
    Hello Roger
    PWD6 HD15 VGA socket - RGBHV or YUV, switched via on-screen menu.
    X-Box - if you want the best image and sound I'd look at getting a HiDef cable pack rather than using the AVR-3803 to up convert S-Video. (Not sure if you can get an X-Box to YUV cable or if its X-Box to RGB + a JS Technology RGB2YUV converter you will require; it may depend on you having a PAL or NTSC X-Box.
    Tuner - what is this and are you limited to S-Video out.
    Cables - VanDamme, Supra, BetterCables and others will all build this cable.
    Best regards
    Joe
  6. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    betamac,
    I did not think that the Sony DB-1070 AMP had any component inputs or outputs...just composite and s-video :confused:
    Cheers, Lee
  7. chienmort
    chienmort
    Roger the cable you need will have a VGA male conector on one end and three or five BNC connectors on the other. The BNC connectors will have a red,green and blue lead and these shoulb be used for Pr(V), Y, and Pb (U) respectively.
    There is no benefit to using the VGA input over a component input card except that the component input card may have Phono(RCA) connectors and these are easier to interface with commonly available consumer cables.:lesson:
  8. betamac
    betamac
    Damm ur right no Component on 1070 After looking at the manual it showed it did, but looking at the actual system and nothing :( Looks like gona have to do it the hard way
    It seems i am going to have to buy 2 Component Video boards 1 for DVD player and 1 for Gamecube grrrrrrrr
  9. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    > convert S-Video.
    I will probably upgrade to this later, using the HiDef AV pack.
    I must figure out what connections the cable tuner has.
    If the tuner has SCART w/RGB and the 42PW6 comes with one Scart adapter fitted, I probably use this combination.
    >Cables - VanDamme, Supra, BetterCables and others will all >build this cable.
    Send you an email regarding the cable.
    Thanks !
    Roger
  10. rsamdal
    rsamdal
    Feb 9, 2003
    43
    Norway
    After Joe Fernands reply, I located the Norwegian distributor for Supra cables, only 200m from where I work :)
    They had the right cable in stock for 550NOK ~ £45
    [​IMG]
