Panny 42pv500 pc connection agony
Discussion in 'Desktop & Laptop Computers Forum' started by cyborg666uk, Apr 27, 2007.
  1. cyborg666uk
    cyborg666uk
    At the moment i'm using the vga port to connect my pc to my 42 pv500 which is fine, but i'd like to use the hdmi port...however when i do so i get a very clear picture but with some annoying colour fringing...blue and pink smears around some letters black on white..
    could anyone shed any light on why this would occur?? cheap hdmi cable perhaps??
    simon
  2. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    I would point my finger at the video card/card drivers rather than the cable or the screen.
    My old video card with a 10m HDMI cable gave a good picture with a permanent green tinge. The same cable with a new card works fine.
  3. cyborg666uk
    cyborg666uk
    thing is i didn't notice this problem when i had an hitachi 42pd8700!! my video card is the geforce 6800gs and i'm using the newest drivers i can find.....
    help!!
    si
  4. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    Could it be a screen fault? Have you tried other HDMI sources?
  5. cyborg666uk
    cyborg666uk
    no unfortunately my pc is the only hdmi source i have....just strange that through vga its fine....slightly softer pic thou....will i still get 720p hd through vga if the source is hd and my screen res is set high enough??
    si
  6. xxxx
    xxxx
    Aug 27, 2005
    776
    28
    +23
    Yes, you will, though in my experience with a 42PX60 VGA is hopeless for video.
