Panny 42PA50 from Germany. No Pal I: OK for Sky?
Discussion in 'Plasma TVs Forum' started by socrates1, Jul 1, 2005.
  1. socrates1
    socrates1
    Jan 2, 2003
    209
    +15
    I'm planning on importing a 42PA50 from Germany into Ireland. The specs do not show Pal I, but as I plan to use only Sky digital as a source, can someone please confirm that this is not a problem. I assume it would be a problem if I wanted to use the normal analogue aerial connection, (picture but no sound?). Thanks, KC
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    no problem with sky but i have heard than you can enable PAL-I from the service menu.............Have a search for "PA50" some one had a problem with no sound from tuner and sorted it
  3. socrates1
    socrates1
    Jan 2, 2003
    209
    +15
    Thanks Hornydragon, I'll check that out. KC
  4. equity
    equity
    What I´ve got with PA50 is that I got nice picture on some channels but with buzzing or no sound.I´m using areal and also satelite antena and it happends in both cases.I´ve checked for this problem here but I can´t find anything useful.Have I missed some option in menu?Can someone tell me if it´s possible to solve this problem thought service menu?
    :lease:
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Yes, you can enable PAL-I. I can't remember where it is at the moment, but an ordinary menu, in tuning? Certainly not any sort of engineers service menu, simpler and less dangerous!
  6. equity
    equity
    MAW thank you for a quick reply I just tried it and- nothing happends.In fact PAL is default choice there.Now I´m sure that I can´t it fix it throught the normal menu, I´ve tried it all.Any other suggestion please?
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's there, you have to make it PAL-I not just PAL. My Dad has one of these, I remember having to do it when we installed it, but can't remember what we did.
  8. equity
    equity
    Thank you MAW.Only PAL,SECAM,M.NTSC and AUTO mode-that´s the offer in MENU/SETUP MENU/TUNING/COLOUR SYSTEM.That´s why I have to dig in the service menu I suppose.But I have to be sure what to do.
