Panny 42HD6 Vs 50 showing 720p signal
Discussion in 'Plasma TVs Forum' started by andyatkins, Jul 7, 2004.
  1. andyatkins
    andyatkins
    Nov 19, 2003
    117
    16
    I have to make a final decision in the next couple of days of whether to go foro the 42" or 50" Panny HD 6 series. My sources will be Sky+ & a DVD player (probably Pioneer 575) & will feed the panels VGA port via RGB Scart thru the JS VGA converter thingy. I'll be sitting about 8'-10' from the screen.
    Assuming Sky's HD service is either 720p or 1080i (Reports on Astra standardising on these for thier new satellite seem ot confirm this for me anyway?), my question remains does the fact that the 42" 'only' having a 1024x768 display with oblong pixels make a noticable difference to an HD image compared to the 50" with 1366x768 square pixels. Clearly there wud be some horizontal scaling going on with the 42" panel but when you view an HD signal is it truly noticable?
    I saw one of those Sagem DLP projectors @ Comet last week running 720p material & it was gob-smacking. I want to feel comfortable that the panel I buy shows an equivalently impressive image & suspect the 42" will be fine but am looking for some re-assurance.
    Would be particulalrly pleased to hear from existing 42HD users who may have played out 720p signals on their panel.
    Many thanks
  2. andyatkins
    andyatkins
    Nov 19, 2003
    117
    16
    Shameless bump - c'mon guys what do you think?
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Problem here is that nobody has a 720p source. I've used Windows media player 702 stuff on a 42HD, I have no complaints, but PC sources are often different to video sources. If you are going for an HD panel a scaler is a useful addition. That will add £1000 to the bill, making a HD42 the same roughly as a 50. But taking all scaling and processing away from the panel is the way to go with either of these for the very highest picture quality, as both of them need scaling both vertically and horizontally.
