panny 42" wall bracket
Discussion in 'Home Cinema Buying & Building' started by chriswynn, Jul 11, 2004.
  1. chriswynn
    chriswynn
    Is there anybody out there that has a wall bracket for my panny 42" pa20 I can buy or even swap it with my glass alpha stand (cost £300)
    As you can tell I plan to mount it on a wall with a twist?
    The twist is I plan to make a false chimney breast and make a cutout in the the middle for the panny to sit in. I know I will have to make it big enough for air flow etc. But has anyone seen any pics of this done on the net if so could you direct me.
