panny 42 viera and e55 recorder advice please
Discussion in 'Blu-ray & DVD Players & Recorders' started by laurence harvey, Oct 9, 2004.
  1. laurence harvey
    laurence harvey
    Hi all, viera 42 and panny e 55 recorder arriving monday from john lewis, can anyone tell me if its worth buying componant leads or sticking with good scarts that i allready have. also, does anyone know if the recorder will be multi region, john lewis had no idea :(
    thank you for any info you can provide
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Component leads should be better although the difference won't be as apparant as going from composite to scart say.
    The dvd recorder will NOT be multiregion.
  3. laurence harvey
    laurence harvey
    thanks m8, much appreciated.
  4. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,123
    London
    +393
    Vast difference between components and scarts. Go component.
  5. Goober11
    Goober11
    Apr 30, 2003
    116
    London
    Is the Viera any good with the e55. I have the e55 but am thinking about the Veira - what does the Q-Link do on the e55?
  6. cj28
    cj28
    Using the E55 with the Viera allows you to set a timed recording using the DVB Guide. This is very useful, you switch the TV and E55 into standby and then the TV switches on the tuner (withou the screen switching on) and starts the E55 recording automatically. The whole system integrates really well. I have connected my E55 to 42PE30 by good quality SCART (RGB) and component (progressive). There is a slight improvement with component although it's not dramatic. I think this is probably a reflection of the RGB being so good anyway. Not convinced it's worth spending too much on component cables if you already have a good SCART cable.
    CJ
  7. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,123
    London
    +393
    Component is the premier connection and will enable you to get Progressive Scan.
    Scart is inferior and will only limit you to RGB.
