Panny 42"pe50 alternative desk stand
Discussion in 'Plasma TVs' started by Motobug, Sep 8, 2005.
  1. Motobug
    Motobug
    Jul 7, 2004
    999
    +19
    I am looking to buy a 42 inch PE50 but I need to find an alternative desk stand. The Panny version is too high and I really want something which keeps the Plasma as close to the AV unit as possible.
    Does any one have any ideas, the only one I have found so far is Unicol.
    Moto
  2. gnikolaidis
    gnikolaidis
    In tjis case you have to order stand TY-ST42PX5W which raises the screen only by about 6.5 cm. You can have a look at it here
  3. UrbanT
    UrbanT
    Jan 6, 2002
    12,882
    Aldershot, Hants
    +3,038
    Is there a link to a UK supplier for this stand. I have searched the stand number, but can only find it as a swivel base available from a UK supplier
  4. Motobug
    Motobug
    Jul 7, 2004
    999
    +19
    gnikolaidis, thanks, just what I was looking for. If anyone has any other ideas they will be appreciated.
    Moto
  5. gnikolaidis
    gnikolaidis
    I sourced mine from http://www.technikdirekt.de, I am not aware of UK suppliers but I am pretty sure if you ask around it would be available since it is standard Panasonic gear.
  6. kenji-san
    kenji-san
    i'd just say that i had this stand at first, and i thought it somehow made the plasma look cheap-ish and clumsy.
    the other one,
    http://www.produkte.panasonic.de/product/product.asp?sStr=5@-@1@13@40@297@@@@@TY-ST42PA50W@Viera|Plasma-Zubeh%F6r@&altMod=N&upper=&prop=
    looks so much more refined and elegant, and perfectly complements the plasma.
    the two small foots sticking out on the bottom looks grim compared to the round delicate one on the other.
    All a matter of taste of course:)
