Panny 37w7 video options
Discussion in 'Plasma TVs' started by First-Timer, Dec 21, 2004.
  1. First-Timer
    First-Timer
    I have just ordered my first plasma - panny 37w7 with component board. Problem is I am confused by all the connection options. I have a Denon 2805 av receiver - bought because I thought that I could run my DVD player, xbox, cable tv and VHS all through this, upconverting all sources to component output.
    Will this get the best from my plasma? Should I hook up the prog scan dvd up direct? Will the cable TV picture be no good compared to CRT tvs?
    Ta
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    well hook XBOX VCR and DVD via amp to componet board on Screen but for cable use th JS technology RGB>VGA converter (better quality than composite via amp which is only other option
