Panny 37PW5/TUPTA600B setup
Discussion in 'Plasma TVs Forum' started by petrolhead, Nov 1, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    Just purchaced the above combination. For those of you who don't know the TUPTA600B its their tuner box (see here .
    I was wondering if anyone else here uses their tuner box and if so have experiments with DVD input ie do you use the RGB or Component, was there much difference and did this affect lip sync.
    Also any other setting I need to be aware of?
  2. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    i am using a arcam dv88 basic model through the component inputs and have not noticed any lip-sync problems as of yet, the only problems i have come up against were a bit of flickering when i had weak signals from the anologue signal, the signal from telewest digital through the scart rgb if is in general quite good hope this helps
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    Re Lip Sync, seems ok with DVD, just hit and miss with TV.
    So John did you try RGB before going component with you DVD and any difference?
  4. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    no sorry have not tried dvd through r.g.b. just assumed component would be the best choice
  5. moeman
    moeman
    Have my Pioneer DVD and Sky+ going through the tuner on RGB, pictures are fine. I havent noticed any lip sync probs at all.
