Panny 37PE30 cabinet stand help!!!
Discussion in 'Home Cinema Buying & Building' started by Tejstar, Oct 24, 2004.
  1. Tejstar
    Tejstar
    Dec 4, 2002
    22,874
    London
    +1,131
    I have this Panny plasma with cabinet stand arriving a week on Monday but ignorantly didn't check whether my current centre speaker will fit in the cabinet. Could anyone who has the 37pe30 stand do me a favour and check out the width of the tray for me?
    I'm trying to fit a centre speaker with the following dimensions:
    Height: 12cm
    Width: 61cm
    Depth: 10.5cm
    I don't see there being a problem height wise but I'm worried that width wise it won't fit :(
    If it doesn't fit I may just have to abandon the stand and get the pedestal stand instead (much against my wishes!)
  2. trebor21
    trebor21
    Oct 11, 2004
    35
    Lol what size you think the shelves are?
    Course it will fit! NOt much point in having shelf if something that small doesnt fit on it
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,874
    London
    +1,131
    Logically I thought it should, but from memory they looked a bit small. So I take it the shelves are greater than 61cm width?
  4. trebor21
    trebor21
    Oct 11, 2004
    35
    Well your tv is going to be around 100-110 cms in width so i would hope so!
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,874
    London
    +1,131
    Just popped out quickly to the shops to check.
    The width of the shelves are approximately 63cm wide, so it'll be a tight fit but luckily I'll just be able to squeeze them on!!! :smoke:
