Panny 37 Viera Lip Sync
Discussion in 'Plasma TVs Forum' started by dylanfreak, Jan 26, 2005.
  1. dylanfreak
    dylanfreak
    :hiya:
    I'm about to purchase a 37 Viera but need some help from you experts.
    As an ex VT Editor, accurate lip sync is a must for me.
    Is the Viera o/k in this respect ?
    I'm aware that source material can be out of sync, but I'm a bit concerned
    that the processing in the panel would make the problem worse.
    I will be using Sky + to DVD recorder to viera (component)
    I am not using an AV amp thus don't want to spend loads on kit
    to achieve good lip sync.
    Any info please from all you kind folks
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    I have a 37" viera, and have never had this problem unless it is actually at source IE: certain dvds or sky them selves not getting it right.
  3. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I have viera 42 and have no lipsynch whatsoever. Sky and dvd connected direct.
    When I used component switching through my amp the lipsynch was unbelievable, although I never tried to dial it out, just revised the connections.
