Following on from Elvis Jnr's thread about connecting a th-37pw5b. I have the Denon AVR 2802 which has 2x component outs.
I was planning to use the JS box for sky to VGA and run my DVD and X box through component on the 2802.
I presume I can use both the VGA & component at the same time.
Will this give me the best results, or should I get the JS box to component and daisy chain (RGB) the DVD and SKY??
Also will the panny accept a composite sync into either the V or H, if so then this would be a cheaper alternative. The IXOS scart - 4RCA
[URL}http://www.hificables.co.uk/acatalog/SCART_to_BNC_.html[/URL]
