Panny 37" PW7 - VCR wont work
Discussion in 'Plasma TVs Forum' started by nokianut, Feb 12, 2005.
  1. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    Does any one know why my VCR (pan) wont work with this screen.
    Ive tried a samsung VCR aswell - same problem
    Im using a JS technology Scart to plasma box.
    Also problems lipsync on some cable (ntl) channels.
    Any help would be great . Thanks
    :thumbsup:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Do you mean you are using a JS technology RGB>VGA converter? (THIS will not work with any none RGB Scart output as it is very unlikely that your VCR HAS RGB output this explains why it will not work)
  3. geewhizz
    geewhizz
    Jan 2, 2005
    2,490
    +91
  4. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    yes its a JS technology RGB>VGA converter. -- Will any VCR work with this.?
    Would the VCR work if I got a Panny scart terminal board or will it still need to be RGB ?
  5. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    [SIZE=5 :confused: ]yes its a JS technology RGB>VGA converter. -- Will any VCR work with this.?
  6. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    VCR???? What's that? :rolleyes: ;)
  7. jonl1973
    jonl1973
    Jan 20, 2005
    39
    +7
    The JS RGB->VGA converter only accepts an RGB signal on its scart input so won't work with most (all?) VCRs which output only composite video over scart.
    The SCART socekts on the scart terminal boards should be like 'normal' scart sockets you'd find on any TV so I don't think there will be any problem connecting a VCR composite signal to them. Can anyone confirm this for definate?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Well as that is NOT RGB it wont work (Yelllw RED and WHite RCA terminals are Composite video and stereo audio not RGB)
    For this and a VCR you would need either ther Basic Video board (composite OR S-video) or the Panasonic Scart board (RGB or Composite)
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    Does the plasma not have a composite input on it ( yellow RCA jack?).
    If so you can either buy a scart to composite adaptor ( very cheap couple of quid) or you might even find a dedicated composite out RCA socket on your VCR. This will be loads cheaper than buying the scart board for the plasma which by all accounts is very noisy and nasty anyway.
  10. geewhizz
    geewhizz
    Jan 2, 2005
    2,490
    +91
    So if the scart on the back of the sony is RGB out and i am plugging everything into the sony thats composite, then it take it wont work.
    currently it works like this.
    composite in> sony RGB scart out> Plasma. ( PQ is Good with just the scart )
    But will this work ??
    composite>sony RGB scart>JS RGB to VGA>Plasma. Yes/No
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    geewhizz your avatar is perfect mate what is feeding composite into SONY????(unless sony is doing some pretty fancy DSP then it wont work
  12. geewhizz
    geewhizz
    Jan 2, 2005
    2,490
    +91
    Yip avatar is how i am everyday with everybody. :rotfl:
    So got the old style cable box ( black one ) all that has is an ariel out socket and thats going into the video, i have a scart/rca going from video to sony then scart>plamsa scart.
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    urgh analogue cable and plasma.........NASTY so JS RGB>VGA wont work for that (will if upgrade to digital cable tho.) or send cable to scart (YUK YUK YUK YUK) and us RGB>VGA for sony...................
  14. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    What do all the other owners of a PW7 use to connect their VCR ?
  15. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    chuck 'em out and buy decent dvd recorder :)
  16. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    tell that to my 2 yr old when he wants to watch bob the builder on VHS
  17. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    :D good point you can't argue with a 2 yr old! ...well you can...but you won't win!
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Buy bob the builder on DVD (cheapest option) or get a scart board £120-150 or video board (£60-80)
  19. nokianut
    nokianut
    Feb 11, 2005
    11
    London
    Does anyone know of a VCR that has RGB output -- as this may be cheaper still ?
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    LOL there was one. a panny S-VHS edit deck semi pro retailed for around £1000 when it was new 10 years ago.......(there is no ther cheaper option than BOB the builder on DVD) or the Video board TY-42TM6V (RCA's), TY-42TM6BB (BNC's)
  21. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    A 2nd hand iscan ultra might be an option for the VCR? £250 should do it, but you are still barking up the wrong tree. Time to get into the 21st century, methinks. And get digital cable whilst you are on the way.
  22. rhodos
    rhodos
    Oct 3, 2004
    1,665
    63
    Wirral
    +158
    Or use the DVD recorder trick if you have both. It converts RGB as well as composite and svideo to whatever is on the output. In my case component to PW7. I haven't checked the scart o/p has the converted signal and not just a passed thru signal but I can guarantee as many can that the component will carry a converted composite signal.
  23. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    true but watch out for macrovision going from VHS to DVDR......
  24. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    This thread truly amazes me...
    Its hard to believe a bog-standard VCR, which is the least technologically advanced bit of AV kit we're ever likely to own, wont play ball with the plasma.
    Unbelievable, just unbelievable....
    Did anyone answer the query though about whether the SCART board for the PW7 will accept the VCR input though?? I didnt see that one if it did
    As an alternative, could i just err..copy my VCR tapes to DVD-R, even the commercial, purchased, pre-recorded ones, is that legit? Am I allowed a "backup for my own use" like I am allowed with computer software???
  25. Supersonic72
    Supersonic72
    Jan 10, 2005
    246
    Just thought....theres the option of the much slated Panny mediabox...
    Wouldn't that be a go-between the PW7 and the VCR???...
    If so...then there will be a lot of them going for a song on ebay soon !!
  26. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    Well no what's unbelievable is that 3 seperate people ( unless some of you have registered twice?) are now asking questions in this thread and have effectively hijacked it from the original poster.
    Its got nothing to do with the VCR being technologically advanced or not all the information you need is in this thread.
    Secondly its perfectly obvious thatthe plasma will work just fine with a VCR as long as you have the right inputs on the plasma , as no-one has bothered to reply as to whether the plasma comes with a composite input ( I actually have one myself but only use the vga and s-video inputs so can't remember myself if it has a composite...probably but I don't know if its a seperate board or not.)
    You know what I might even have another input board knocking around somewhere it might even be the scart.
    Yes it will work with the scart , yes it will work with the composite input. Go buy one if you haven't already got one or sort out some other way of feeding the plasma ...ie as someone pointed out an offboard scaler or even a PC with a capture card running Dscaler.
  27. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    I have a Panasonic S-VHS VCR hooked up to my PWD6 via s-video to my Denon 3805 amp then via component. I get a reasonable picture from the analogue tuner, but a flickering picture from video tapes, both recorded and pre recorded. It is very difficult to watch. The recorded tapes are s-vhs ones. The picture was fine on our old CRT, but something is interfering with it on the plasma.
    We rarely use our VCR, but very occasionally we have programme clashes that can't be resolved with our TiVo alone. Anyone have any ideas?
    Teresa
  28. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    I'd have said macrovision before you mentioned recorded tapes.
    I use the s-video in on my 37pw5 plasma a fair bit and its fine. dsthere anything else plugged into the plasma ...might be a conflict of some sort. Also does the vcr have a TBC or other picture processing modes , this might be throwing off the deinterlacing in the plasma.
  29. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    Thanks for the reply Mr.D. It may be the amp throwing the signal out a bit as it's converting it to component. Normally when we try to watch the VCR there are no other active inputs into the amp, but our TiVo will still be active into the plasma. I'll look into your suggestions. I also have a spare scart input on my PWD6, so when I'm brave enough to tackle the cabling behind my set up, I'll give that a go.
    Teresa
  30. Mr.D
    Mr.D
    Jul 14, 2000
    11,200
    +1,243
    Always connect direct and then work your way back from there to isolate the problem.
