panny 37" fireplace install
Discussion in 'Members DIY Home Cinema Showcases' started by daveqpr, Jan 3, 2007.
  1. daveqpr
    daveqpr
    It started like this just after plastering
    [​IMG]
    then some paint
    [​IMG]
    tv and fire installed
    [​IMG]
    Av forums powerbuy slim tilting bracket
    [​IMG]
    close up of home made speaker bracket
    [​IMG]
    all wiring down left side of fireplace in "false wall" plasterboard and 6"x9" access panels (can be painted to blend in)
    [​IMG]
    [​IMG]
    my first attempt at an install with minimal wires on display, in fact its hard to spot wires from the front.
    however now tv is on wall wish i had gone for 42" display:(
  2. Miniholic
    Miniholic
    Apr 26, 2001
    3,060
    The Shire
    +399
    Great looking install.:smashin:
    The plasma looks just right, a 42" would probably look a bit much, although if it will fit on the same mount why not.:devil:
    Love the speaker brackets, are they toggle switch plates?
  3. Mac User
    Mac User
    Sep 27, 2006
    4,551
    Norfolk
    +309
    Nice job ..
  4. digitalfailure
    digitalfailure
    Dec 30, 2006
    68
    nice install :smashin:
    I think a 42 would look ok, i have a 42" pio above my fireplace, but it'll extend above you L & R speakers and you might lose the panning effect.
    What speakers are they?
    I'm looking for a new set of small sats to go with my screen :D
  5. eastman3000
    eastman3000
    Mar 14, 2006
    447
    +19
    Nice setup mate! I also have the 37 panasonic.
    I liked the way you made your speaker brackets. Tell me how!!? what speakers/system are they?
    nice one
  6. daveqpr
    daveqpr
    Rear speakers and sub. Speaker system is from an all in one pioneer
    dv/333 system about 1 1/2 yrs old. Sound is good but not mindblowing, though as i live in a semi detached house I cant crank it up too much as I think of the neighbours (other side of fireplace)
    [​IMG]
    Center speaker
    [​IMG]
    Speaker brackets made from screwfix chrome blank plates and speakers mounted with 5m bolts left over from tv bracket (bought 5m nuts to lock in place) all drilled out by me
    [​IMG]
