Panny 36PL32 Geometry Issue
Discussion in 'General TV Discussions Forum' started by IndianaBlues, Sep 8, 2005.
  1. IndianaBlues
    IndianaBlues
    Jul 28, 2005
    2,036
    +355
    Have had my telly for almost a week now, and my main gripe is that the geometry or the picture looks out, in a pin-cushion type way, especially at the corners (which I suppose you have to expect but is still noticeable) when vertical lines are displayed. This is also shown when in 4:3 mode, the top right hand corner of the supposedly vertical side of the picture warps inwards. Is this something that I can fix myself, if anyone has the service menu commands? Is it worth calling Dixons, or easier just to live with it?
    A few more minor things I've noticed are that when watching dvds on my S-VHS out player, vertical lines look wobbly throughout the screen, backed up by the THX optimiser. Also, again in 4:3 mode, it appeared that the tv was overscanning as the left-hand edge of one of the rectangles was missing.
    Cheers,
    Nic
  2. Sofa1
    Sofa1
    Jul 1, 2005
    178
    +3
    you can correct geometry in service menu, but it will never have 100% straight lines.
  3. Slimchandi
    Slimchandi
    Dec 23, 2004
    467
    +3
    Any idea how to access the service menu on said model?
  4. 88mphster
    88mphster
    Sep 3, 2005
    5
    3
    I followed the instructions here and was able to modify the geometry on my 36PL32.
    As it says in the link post - remember to write down your original values in case something goes wrong.
  5. Slimchandi
    Slimchandi
    Dec 23, 2004
    467
    +3
    Cool, I was looking for this. Hope I don't screw up my telly, just need a copy of DVE now...
    Edit: Just need blah to deliver my copy of DVE!
  6. IndianaBlues
    IndianaBlues
    Jul 28, 2005
    2,036
    +355
    Thanks! That's just what I've been looking for, unfortunatley am away straight from work today so won't get to try it out until Monday :rolleyes:
    One (probably silly question) - the link lists these as the settings to play with:
    H-pos (horizontal position)
    V-pos (vertical position)
    H-amp (horizontal amplitude)
    V-amp (vertical amplitude)
    EW-amp1(EW-amplitude coarse pincushion looks like)
    EW-amp2(EW-amplitude finer/corners looks like)
    Trapez1(Trapezium comp_ suck it and see!)
    Trapez2(finer of the above suck it and see!)
    V-lin (vertical linearity)
    V-sym (vertical symmetry used with above to sort vertical linearity !)
    What exactly is Vertical Linearity?
