panny 36pb50 horizontal interference
Discussion in 'General TV Discussions Forum' started by colesy, Dec 22, 2002.
  1. colesy
    colesy
    Dec 28, 2001
    729
    +16
    After having a new tube fitted under warranty I have now noticed that I am getting thin horizontal lines that look like interference across Sky and anologue sources.
    I have moved all my equipment, turned things off one by one and all off together, fed the aerial directly to the TV, and problem is still there.
    I only notice from time to time, but now I am looking for it all the time.
    I have decent leads, co-oax and scarts and tried swapping them, but no joy.
    Any ideas on solving this????
    Many thanks
  2. mansell
    mansell
    Feb 11, 2002
    914
    28
    Bristol
    +39
    do you get this whilst wacthing DVD's ?
    You could try the TV in another position as it could be interference from another source ?
    if all else fails you maybe looking at the FLY Back lines on the tube , this would require a Engineer to make adjustments
  3. colesy
    colesy
    Dec 28, 2001
    729
    +16
    Thanks Mansell,
    I do get the interference when a dvd is playing, and have tried moving the TV.
    Guess I'm not getting this fixed this year then.
  4. colesy
    colesy
    Dec 28, 2001
    729
    +16
    I have phoned the shop that replaced the tube, and they said it would sort itself out in a few weeks because it is settling down. If not they have to have it back in a few weeks time. They would have to adjust something in the service menu with "big equipment connected".
    Anybody know what they would adjust in the service menu??
