Panny 32PM1 & 32DTX1
Discussion in 'General TV Discussions Forum' started by Biccy, Oct 20, 2004.
  1. Biccy
    Biccy
    Having FINALLY chosen & ordered my TV tonight, the Pan 32PM1, i've been looking at the Panasonic website & seen the IDTV version, the 32DTX1. The IDTV isn't something i need as i have Sky+, however the TV itself looks nicer (casing) than the all silver im getting, & it can be had for same price. Also im guessing it'd have a higher re-sale value when i replace with HDTV in a few years time. Does anyone know if the PQ should be exactly the same as the analogue PM1 as it uses the same Quintrix F tube & has the same spec on paper (apart from the addition of ''Artificial Intelligence'' & differenet chassis reference), or does the fact that inside the box the IDTV effects PQ somehow? If not i'd swap my order. Thanks in advance.
