Panny 32 pk2 any recommendations?
Discussion in 'General TV Discussions Forum' started by Tel boy, Aug 19, 2001.
  1. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Anyone out there got one of these TVs ?<br />Any bad / good points? <br />Have read of a humming coming from the rear speakers on the PG series of TVs, does the same effect this model (pk2)?<br />The best price I have seen is from Empire direct £840, anyone know of anyone cheaper on the net?<br />Cheers, Tel.
  2. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Come on …you helpful lot… <img src="biggrin.gif" border="0">
    some1 out there must have had some dealings with a PK2 <img src="confused.gif" border="0">
  3. Aidan
    Aidan
    I have the Panny 32PK1 which is similar to the PK2 only it is Nicam not Pro logic (not needed as I use a stand alone amp) and is 50Hz not 100Hz (don't like the smearing you can get with 100Hz). Picture is fantastic, good geometry and definition. HCC have a review of the PK1 here - <a href="http://www.homecinemachoice.com/testbench/Televisions/Panasonic/PanasonicTX-32PK1.shtml" target="_blank">http://www.homecinemachoice.com/testbench/Televisions/Panasonic/PanasonicTX-32PK1.shtml</a> I have had this TV for a year now and I am very pleased with it and would recommend it to anyone.
    Aidan.
  4. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Aidan thanks 4 your reply,<br />I was considering the PK1 (think it’s now called PK3) and following you route of getting an amp etc…but to be honest we don’t watch that much TV so I thought if I got the PK2 I could kill 2 birds with 1 stone. I appreciate that the sound from a stand-alone amp would be better & and the PK2 is only Pro-logic & 50 Hz, but like you I can’t get away with 100 Hz. <br />I wondered if the rear speakers hummed / buzzed on the PK2 as I’ve seen posts complaining of this on the PG range, Don’t want to buy a Duffa!<br />Cheers Tel.
  5. baccattack
    baccattack
    Jul 27, 2000
    232
    28
    England
    +31
    Having been an owner of a 32 PK2 since may 2000 I can confrim that it is an excellent set. I never experienced any hum from the rear surounds which I used up until March this year when I upgraded to 5.1 sound. The only limiting factor you may find is that this model only has two scart sockets although for me it's not a problems as I route the rgb signal from my stb through my dvd player. Also the cabinet design is not the most stylish out there. Otherwise no problems.
    Stephen.
  6. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Thanks 4 your reply Stephen, <br />I was beginning to think no one owned a PK2 judging from lack of posts.<br />How did you find the PK2 sound wise? <br />Obviously it’s not going to compare with a separate amp set-up, but do you think it’s worth having a PK2 over a PK1 ( think this model is now known as PK3) Does the Pro-logic make that much difference.<br />Cheers, Tel.
  7. baccattack
    baccattack
    Jul 27, 2000
    232
    28
    England
    +31
    Tel,
    Obviously the sound can't possibly compete with that I now have via my Denon reciever and B+W speakers. However as far as pro-logic televisons go I thought it was pretty impressive and I certainly wasn't dissapointed when watching movies such as the Matrix on DVD. The reason I went for a pro-logic set was because I thought it would be a while before I went the full seperates route. Now I only use the Nicam for watching ordinary tv which is still very impressive.
    Stephen.
  8. Tel boy
    Tel boy
    Apr 2, 2001
    147
    UK-North East
    +5
    Thanks 4 the info Stephen.<br />Sounds like (no pun intended) the PK2 is a good all-round performer &, as the price is right it looks as if the 32 PK2 is the TV 4 me.<br />Only 1 MAJOR obstacle to overcome now….the wife!! <br /> <img src="rolleyes.gif" border="0"> <br />Tel. <img src="biggrin.gif" border="0">
