Pannasonic pt-ae100e help?
Discussion in 'Projectors, Screens & Video Processors' started by tirpas, Oct 10, 2003.
  1. tirpas
    tirpas
    Hi ,Ihave pt-ae100e
    I have got a problem with this pj.,its the green and pink colors hue in the botom corners of the screen,on the grey.
    I hope there are posible things to do about it.?
    thanks for any help,and sorry for my english.
    Andrew.Lithuania.
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,225
    Scotland
    +179
    Have you tried testing the colours using the service mode.
    With the remote, go the the OSD menu and press enter and hold for 5 seconds. A new set of menus should appear.
    From there you should be able to do a panel test which will tell you if have stained/damaged lcd panels.
    If they are stained/damaged and the machine is still under warrenty get Panasonic to replace asap.
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    its a common problem with lcd projectors i have slight colour uniformity problem on my ptae100 but you can only see it on the grey screen, but not when watching a movie, if its very bad and you can notice it when watching a film and its still under warranty i would give panasonic a call
