pani lcd 37lzd70 power on preference
Discussion in 'Freeview & YouView' started by barrymorri, Feb 7, 2009.
  1. barrymorri
    barrymorri
    i have in the set up menu selected AV as my power on preference but when i turn on the tv it starts at the dvb freeview screen .
    anyone have any idea why?.
    please help.
  2. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    have you done an initial installation yet?
    are you going POWER off, or just to standby?
    are there more than two options? If so, do any work?
  3. barrymorri
    barrymorri
    thanks for the reply,:smashin:
    i have had the tv for over 12 mth now so initial installation has been done.
    i power off every night ,
    and standby from time to time and tried start up on each.
    there are only the two options , av or tv. i have selected av.
  4. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    what happens if you select TV?
    when you go to the menu does it already show AV? Wondering if you are not saving your choice
  5. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    Is your AV source already ON when you power the TV? Or are they all switched together?
    Did you :rtfm: ?
    "Power on Preference
    Set to “TV” to view picture from TV tuner.
    Set to “AV” to view input from an external equipment connected to a SCART terminal,
    e.g. satellite receiver (TV / AV) • The external equipment must be switched on and sending a control signal for
    automatic switching at power on to occur."
  6. barrymorri
    barrymorri
    no option to save ,just change to av . then i power down ,turn on ,freeview appears. then if i go to the menu ,av still selected .:confused:
  7. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  8. scribbler101
    scribbler101
    Jun 17, 2008
    1,407
    63
    +113
    "The external equipment must be switched on and sending a control signal for automatic switching at power on to occur"
    I presmue it is ON (?) but
    I don't know what it means by sending a control signal. Try powercycling with the AV source actually playing.
    Then I think it's time to phone the mfrs helpline!
    Do keep us informed.
  9. barrymorri
    barrymorri
    think i will do that as nothing advised seems to work.
    cheers anyway.
    will keep informed,:smashin:
  10. barrymorri
    barrymorri
    SORTED.
    old dumbo here had the scart connected to sky vcr socket , not sky tv socket.
    although i now have a sky engineer booked as there's an iffy connection with sky box tv scart socket.:suicide:
