Panel adjustment feature?
Discussion in 'Projectors, Screens & Video Processors' started by Kahless725, Nov 5, 2004.
  1. Kahless725
    Kahless725
    does anyone know what the panel adjustment feature is on the Z3? Does it mean you can allign the three panels independantly so you get a good focus?
    Seen here :- http://www.shootandshow.co.uk/ you need to choose projectors and then choose the Z3.
    Regards
    Robert.
  2. zAndy1
    zAndy1
    Nov 26, 2002
    22,696
    2
    5
    163
    +9,036
    It's for reducing VB, that's what it says in the manual anyway, you calibrate using test patterns, the patterns appear in the order of red, green and blue and you adjust bright dialog to minimise VB in the bright part of the picture and dark dialog to minimise VB in the dark part of the picture.
    Cheers,
    Andy.
  3. Kahless725
    Kahless725
    Thats another thing on the list where they have listened to customers. If I had the cash this min I think I woul just order one, probably good that I dont as I should really test it first :)
